Configuration Completion
Congratulations! You've almost completed the configuration of your stromleser.one. In this final step, we'll check if everything is working correctly.
What Happens Now?
After you've set all parameters, your stromleser.one will:
- ✅ Check the connection to the meter
- ✅ Read first data
- ✅ Save configuration to the cloud
- ✅ Begin regular data transmission
Verifying Configuration
1. Check LED Status
Look at the LED on your stromleser.one:
- Blinking green = Everything's running perfectly! Data is being read
- Blinking red = There's a problem – see Troubleshooting
More on LED indicators: Understanding LED Indicators
2. First Data in the App
- Go to the device overview in the app
- Select your stromleser.one
- You should now see the first data:
- Current consumption in watts
- Meter reading
- If available: PV feed-in
Note
It may take up to 30 seconds before the first data appears in the app.
What If No Data Is Displayed?
If no data appears after 1-2 minutes:
Step 1: Check LED
- LED blinking green: Everything ok, wait a bit longer
- LED blinking red: Perform a Factory Reset
Step 2: Check Position
- Is the reading head correctly positioned on the optical interface?
- Is the logo facing forward (toward you)?
- Is the magnet firmly attached to the meter?
See also: Physical Installation
Step 3: Meter Compatibility
- Check if your meter is really on the compatibility list
- Some meters need to be activated by the grid operator first
Step 4: Contact Support
If nothing helps:
Next Steps
After successful configuration, you can:
- Reading Data - Learn how to interpret your consumption data
- Understanding Charts - Use statistics and charts
- Home Assistant Integration - Connect with your smart home
- Local API - Access data directly
Tips for the Optimal Start
Energy Saving Starts Now!
- Recognize consumption patterns: Observe when your consumption is highest
- Identify power guzzlers: Turn devices on and off individually to see their consumption
- Set goals: Define consumption targets and monitor your progress
- Check regularly: Look at the app daily to develop awareness of your energy consumption
You're Ready!
Your stromleser.one is now fully set up and ready to help you save energy. Good luck!
Your energieleser Team
