Compatible Electricity Meters for stromleser.one
The stromleser.one is compatible with a wide range of digital electricity meters that have an optical D0 interface.
Compatibility List
You can find the complete and up-to-date list of all compatible electricity meters here:
Tip
The list is updated regularly. If your meter is not listed but has an optical D0 interface, there is a high probability that it is still compatible.
Meter Not Found?
If your meter is not listed:
- Check if your meter has an optical D0 interface (usually a small round or square sensor on the front)
- Email us at info@energieleser.de – we'll add your meter to our wishlist
- Contact our support for more information
- In many cases, unlisted meters with D0 interface can also be read
Next Steps
After confirming compatibility:
- Check the box contents
- Begin with the installation
