Tariff Parameters
With tariff parameters, you set how much you pay for your electricity. This allows the app to show you not only consumption but also the resulting costs.
Why Set Tariff Parameters?​
Without tariff settings, you only see your consumption in kWh. With tariffs, you learn:
  • πŸ’Ά How much your consumption costs
  • πŸ“Š Cost development over time
  • πŸ’‘ Savings potential in euros
  • 🌞 Revenue from PV feed-in (if available)
Tip
Tariff configuration is optional. If you only want to see consumption, you can skip this step!
Accessing Tariff Parameters​
  1. Open the stromleser app
  2. Select your stromleser.one
  3. Tap on Settings βš™οΈ
  4. Select Tariff Parameters
What Parameters Are There?​
1. Basic Charge​
What is it? The monthly basic charge of your electricity tariff, independent of consumption.
Where do I find it? On your electricity bill, often referred to as "basic fee" or "basic charge."
Example:
  • €9.90 per month
  • €12.50 per month
Entry: Enter the amount in euros, e.g., 9.90
Good to Know
The basic charge is automatically broken down to days to calculate daily costs.
2. Energy Price (Single Tariff)​
What is it? The price per consumed kilowatt-hour (kWh) of electricity.
Where do I find it? On your electricity bill, listed as "energy price" or "ct/kWh."
Example:
  • 32.5 ct/kWh
  • 28.9 ct/kWh
  • €0.325/kWh (equals 32.5 ct/kWh)
Entry: Enter the price in cents per kWh, e.g., 32.5
3. Dual Tariff (HT/NT) - Optional​
If you have a dual-tariff meter (e.g., day/night tariff):
High Tariff (HT)​
  • Usually daytime electricity
  • Usually more expensive than low tariff
  • Example: 35.2 ct/kWh
Low Tariff (NT)​
  • Usually nighttime electricity
  • Usually cheaper than high tariff
  • Example: 24.8 ct/kWh
Time Windows: The app automatically recognizes from the meter data when HT and when NT applies. You don't need to set times!
Important
Only select "Dual Tariff" if you actually have an HT/NT meter!
4. Feed-in Compensation (PV Systems) - Optional​
What is it? The amount you receive from your grid operator per kWh fed into the grid.
When is it relevant? Only if you have a photovoltaic system and feed electricity into the grid.
Where do I find it?
  • In the feed-in agreement with your grid operator
  • On the PV billing statement
  • Depends on the year your system was commissioned
Examples:
  • 8.2 ct/kWh (systems from 2023)
  • 10.5 ct/kWh (systems from 2020)
Entry: Enter the amount in cents per kWh, e.g., 8.2
Example Configurations​
Simple Tariff Without PV​
Basic Charge: €9.90 / month
Energy Price: 32.5 ct/kWh
Tariff Type: Single Tariff
HT/NT Tariff​
Basic Charge: €12.50 / month
Energy Price HT: 35.2 ct/kWh
Energy Price NT: 24.8 ct/kWh
Tariff Type: Dual Tariff (HT/NT)
Single Tariff With PV System​
Feed-in Compensation: 8.2 ct/kWh
Saving Settings​
After entering all tariff information:
  1. Check your entries
  2. Tap on Save
  3. Settings take effect immediately
What Happens After Saving?​
The app now calculates:
  • βœ… Daily costs based on your consumption
  • βœ… Monthly projections
  • βœ… Cost comparisons between periods
  • βœ… Revenue from PV feed-in (if configured)
Tariff Adjustments​
When Should I Update Tariffs?​
  • πŸ“† When your electricity provider raises tariffs
  • πŸ”„ When switching providers
  • πŸ’° If feed-in compensation changes
How Does a Change Affect Things?​
  • New values apply from the time of change
  • Historical data is not recalculated retroactively
  • The app shows in the timeline when tariff changes were made
Where Do I Find My Tariff Information?​
On the Electricity Bill​
  1. Look for "Price Breakdown" or "Tariff Details"
  2. Basic charge usually at the top of the document
  3. Energy price often listed in a table
From Your Electricity Provider​
  • Online customer portal
  • Contract documents
  • Customer service hotline
Typical Terms​
  • "Basic Fee" = Basic Charge
  • "Consumption Price" = Energy Price
  • "ct/kWh" = Cents per kilowatt-hour
  • "HT/NT" = High Tariff/Low Tariff
  • "Day/Night" = HT/NT tariff
Next Step​
After setting tariff parameters, complete the configuration:
➑️ Complete Configuration
Frequently Asked Questions​
Do I need to provide tariff parameters?​
No, it's optional! Without tariff parameters, the app only shows consumption values in kWh, not costs.
Can I change tariffs later?​
Yes, at any time! Just go to settings and adjust the values.
What if I don't know my energy price?​
Check your last electricity bill or contact your electricity provider. Alternatively, you can skip this step and add it later.
Is historical data recalculated?​
No, tariff changes always apply from the time of entry. Historical data remains unchanged.
Can I store different tariffs for different periods?​
The app automatically stores when you made tariff changes. This keeps historical cost calculations accurate.
Need Help?​
If you have questions:
