Physical Installation
Meter already unlocked?
If not done yet, first unlock your electricity meter in extended mode: Unlock electricity meter.
Installing the stromleser.one is usually straightforward and takes only a few minutes.
Step 1: Attach stromleser.one to the meter
Installation on the meter is very simple in most cases:
  1. Check orientation
    • Make sure the stromleser symbol on the TTL reading head points forward – as if it's smiling at you
    • The meter can only be read correctly in this position
Physical Instalation
  1. Attach to meter
    • In most cases, you can place the stromleser.one directly from the packaging onto your digital electricity meter
Strom logo
  • The magnetic attachment holds the device securely on the meter
Connected on meter
Step 2: Weak magnet on the meter?
If your digital meter has a weak magnet, you can use the included metal disc:
  1. Attach metal disc
    • Stick it on the optical interface
    • Make sure the light source is not covered
Magnet on meter
  1. Alternative mounting with limited space
    • If the cable is in the way due to the plastic base on the meter,
    • You can mount the Wi-Fi module separately thanks to the two-part design of the stromleser.one with the included 3M adhesive pad
Two component design
  • For example, on the side of the meter
Strom on meter
LED indicators during installation
During installation, the LED shows various statuses:
  • Rapidly flashing blue: Wi-Fi setup is being prepared
  • Flashing green: Successfully connected
  • Flashing red: Error occurred – see reset guide
Next Steps
After physical installation:
  1. Connect the power supply to your stromleser.one
  2. Set up the connection in the stromleser app and connect the device to your Wi-Fi
