Factory Reset
If an error occurs during installation or you want to reconfigure the device, you can reset the stromleser.one to factory settings.
When is a Reset Necessary?
A factory reset is required when:
  • ❌ The LED flashes red (error during installation)
  • ❌ The Wi-Fi connection cannot be established
  • ❌ The device no longer responds
  • ❌ You want to set up the device in a new Wi-Fi network
Performing Reset
What You Need
  • A paperclip or a pointed object
  • Your stromleser.one must be powered
Step-by-Step Guide
  1. Locate LED
    • Find the red LED on the stromleser.one
    • It is located on the device housing
  2. Press Reset Button
    • Take a paperclip or similar pointed object
    • Press the red LED with it for about 7 seconds
    • Hold the button until the LED starts flashing
    Reset
  3. Wait for Blue Flashing
    • After about 7 seconds, the LED will start flashing blue
    • This signals that the reset was successful
    • The device is now reset to factory settings
After Reset
After successful reset:
  1. Restart Setup
    • Open the stromleser app
    • Start the setup process from the beginning
  2. All Data Remains Preserved
    • Your previous consumption data in the cloud remains saved
    • You only need to reconnect the device to your Wi-Fi
Important
The reset only deletes the Wi-Fi configuration and device settings. Your consumption data in the cloud remains preserved.
Troubleshooting
LED Does Not Flash Blue
If the LED does not flash blue after 7 seconds:
  1. Press Longer
    • Try holding the button for 10 seconds
  2. Check Power Supply
    • Make sure the device is powered
    • Disconnect and reconnect the USB-C cable
  3. Try Again
    • Wait 30 seconds
    • Try the reset again
Device Does Not Respond at All
If the device does not respond at all:
  1. Check Power Supply
    • Check if the power adapter is working
    • Test a different outlet
    • Check the USB-C cable
  2. Contact Support
    • If the device still does not respond
    • Contact our support
Next Steps
After successful reset, restart the setup process in the stromleser app.
