App Setup for wasserleser
Setting up your wasserleser is done through the stromleser app. Simply follow the steps below in the order shown.
Important
During setup, you will be asked to select your device type. Choose wasserleser from the list.
Setup Steps
Follow these steps to set up your wasserleser:
  1. Download App - Download the stromleser app to your smartphone
  2. Create Account - Create your user account
  3. Select Device Type - Choose wasserleser as your device type
  4. Bluetooth Pairing - Connect your device via Bluetooth
  5. WiFi Configuration - Set up the WiFi connection
  6. Complete Pairing - Finish the setup
Tip
The entire setup takes about 10-15 minutes. Make sure you are near your WiFi router and your water meter.
LED Indicators During Setup
  • Green blinking: Device is connecting to WiFi
  • Blue blinking: Device successfully connected and detecting water flow
  • Red blinking: Connection failed, please retry
Troubleshooting Connection Issues
If the LED blinks red (connection failed):
  1. Wait a few seconds
  2. Disconnect the wasserleser from power
  3. Reconnect and try the setup process again
  4. If problems persist, perform a factory reset (see LED Indicators)
Next Steps
After successful setup, proceed to:
