LED Indicators
The LED indicator on the wasserleser informs you about the current device status.
LED Behavior
The wasserleser uses different LED colors and blinking patterns to indicate the respective device status.
LED Status Overview
SituationLED BehaviorMeaning
No WiFiRed slowly blinkingDevice cannot connect to WiFi
WiFi connection being establishedBlue slowly blinkingDevice is trying to connect to WiFi
WiFi successfully connectedGreen quickly blinking → OFFConnection successful, then LED turns off
Normal operationOFFDevice is working normally, LED is off
After factory resetBlue quickly blinkingDevice is ready for new setup
Water consumption detectedSingle blue light pulse → OFFMeter pulse was registered
What Do the Colors Mean?
🔴 Red (slowly blinking)
The device has no WiFi connection. Check:
  • Is WiFi turned on?
  • Are the WiFi credentials correct?
  • Is the device within range of the router?
🔵 Blue (slowly blinking)
The wasserleser is trying to connect to WiFi. Please wait a moment.
🔵 Blue (quickly blinking)
After a factory reset, the LED blinks blue quickly. This means the wasserleser is ready for a new setup.
🔵 Blue (single pulse)
Water consumption was detected – this is normal.
🟢 Green (quickly blinking)
The WiFi connection was successfully established. The LED then automatically turns off.
⚫ Off
Normal operation - the device is working properly.
Factory Reset
For information on performing a factory reset, see Device Reset.
