Leak Detection
The wasserleser includes a leak detection feature that alerts you when water flows continuously for longer than expected. This helps identify leaks, running toilets, or forgotten taps.
How Leak Detection Works
The wasserleser monitors water flow continuously. If water flows without interruption for longer than your specified time threshold, you'll receive an alert notification.
Setting Up Leak Detection
Access Settings
  1. Open the stromleser app
  2. Select your wasserleser device
  3. Tap the gear icon (⚙️) in the top right
  4. Navigate to Leak Detection settings
Configure Time Threshold
Set the duration after which you want to be alerted:
Example thresholds:
  • 30 minutes: For quick alerts (detects short leaks, but may alert during baths)
  • 2 hours: Balanced setting for most households
  • 4 hours: Only alerts for major continuous flow
Choose based on your typical water usage patterns.
Timer Function
In addition to leak detection, you can set up the timer function to monitor water consumption:
Usage Alerts
Set warnings based on:
  • Time: Alert after water flows for X minutes/hours
  • Volume: Alert after X liters/cubic meters consumed
This is useful for:
  • Monitoring specific appliances (dishwasher, washing machine)
  • Controlling garden watering duration
  • Tracking pool filling
  • Budget management
Accessing Timer Function
  1. Open device settings in the app
  2. Select Timer Function
  3. Configure your preferred thresholds
  4. Enable notifications
Understanding Notifications
When leak detection or timer thresholds are exceeded, you'll receive:
  • Push notification on your smartphone
  • In-app alert with details about the event
  • Timestamp showing when continuous flow started
Common Leak Detection Scenarios
True Leaks
  • Dripping faucets
  • Running toilets
  • Pipe leaks
  • Faulty appliance connections
False Alerts (Normal Usage)
  • Long showers or baths
  • Washing machines with long cycles
  • Garden watering
  • Pool filling
Adjusting Sensitivity
If you receive frequent false alerts, increase the time threshold. If you're concerned about missing leaks, decrease it.
Taking Action
When you receive a leak alert:
  1. Check all water sources in your home
  2. Inspect visible plumbing for drips or moisture
  3. Listen for running water in toilets and pipes
  4. Check water meter to confirm if water is still flowing
  5. Turn off main water supply if you find a serious leak
  6. Contact a plumber if you cannot locate the source
Monitoring Consumption
Use the app to:
  • View real-time water flow
  • Check historical consumption patterns
  • Identify unusual usage spikes
  • Compare daily/weekly/monthly usage
Benefits of Leak Detection
  • Cost savings: Catch leaks before they cause high bills
  • Water conservation: Prevent unnecessary water waste
  • Property protection: Detect issues before water damage occurs
  • Peace of mind: Monitor usage while away from home
For general notification settings, see Notifications.
Troubleshooting
Not receiving alerts:
  • Check notification settings in the app
  • Verify your smartphone allows app notifications
  • Ensure the time threshold is set appropriately
Too many false alerts:
  • Increase the time threshold
  • Review your typical water usage patterns
  • Consider your household's specific needs
Need Help?
For additional support with leak detection:
