Compatible Meters
The wasserleser is specifically designed for water meters with a rotating metal disc. For successful installation, it's important to check whether your water meter is compatible with the wasserleser.
Compatible Water Meters
Water Meters with Metal Disc
The wasserleser is compatible with water meters that have a small metal disc visible above the red wheel.
Compatible Water Meter with Adhesive Pad
Compatible Mounting
Your water meter should have either a flat surface for adhesive mounting or an indentation for adapter mounting.
Compatible Water Meter with Adapter
Incompatible Water Meters
Water Meters Without Metal Disc
Water meters where the red wheel is made entirely of plastic are not compatible with the wasserleser.
Checking Compatibility
Before ordering a wasserleser, please verify:
  1. Metal disc presence: Ensure your water meter has a small metal disc above the red wheel
  2. Mounting surface: Check if your meter has a flat surface or indentation
  3. Accessibility: The water meter should be accessible for installation
Tip
If you're unsure whether your water meter is compatible, send us a photo of your water meter. We'll be happy to help determine compatibility.
