Re-enable cloud connection
You can switch back to normal cloud operation at any time whenever you need the cloud connection again.
Step-by-step guide
  1. Open the web interface
    Open the Stromleser-One web interface again at http://<stromleser-one-ip>/
  2. Go to Settings
    Navigate to Settings → Cloud Connection Settings.
  3. Enable cloud connection
    Click Enable Cloud Connection.
  4. Confirm the dialog
    Confirm the warning dialog to enable the cloud connection.
What happens after re-enabling?
After successfully re-enabling the cloud connection:
  • Data is sent to the cloud again
    All readings are synchronized again and stored in the cloud.
  • Full app usage restored
    The energieleser app can now use the values including history as usual.
  • OTA firmware updates possible again
    The device can receive automatic firmware updates from the cloud again.
When should I re-enable the cloud?
Typical reasons for re-enabling:
  • Firmware updates
    To receive OTA updates, the cloud connection must be enabled.
  • Full app functionality
    When you want to use the Stromleser app with full functionality again.
  • Cloud history needed
    When you want to store historical data in the cloud.
  • Temporary synchronization
    To synchronize data between different devices.
Flexibility
You can disable the cloud connection again at any time if you want to return to offline mode. See the Setup guide for disabling it.
