Power Supply
Powering your stromleser.one is usually very simple and takes only a few minutes.
1. Prepare the power adapter
  • One end of the included power adapter has a USB-C connector
  • Plug the USB-C connector into the stromleser.one as shown in the image
Installation-1
2. Connect power adapter
  • Plug the other end of the cable into the power adapter plug
  • Then connect the power adapter plug to a nearby power outlet
  • As soon as the stromleser.one receives power, the LED will start flashing blue
Installation-2
No outlet nearby?
If there is no power outlet near your electricity meter:
  • We recommend the Energieleser DIN rail socket
  • Can be installed directly on the DIN rail by a qualified electrician
  • Reliably powers your stromleser.one
  • Buy here: 👉 DIN rail socket
DIN rail socket
