Device Removal
If you want to remove your stromleser.one from the app – for example because you're selling it, moving it to another location, or no longer want to use it – you'll find out how to do it here.
When Should I Remove the Device?
- 🏠 Moving to a new apartment/house
- 💼 Selling the device
- 🔄 Re-setup with different account
- 🗑️ Device is no longer needed
Removing Device from App
Step-by-Step Instructions
Open App
- Open the stromleser app
- Go to device overview
Select Device
- Select the stromleser.one you want to remove
- Tap on device to open detail view
Open Settings
- Tap on Settings icon ⚙️ (usually top right)
Remove Device
- Scroll down to "Device Management" section
- Tap on "Remove Device" or "Delete Device"
Confirmation
- You'll be asked for confirmation
- Read notes carefully
- Confirm with "Yes, Remove Device"
After removal, the device is no longer connected to your account. You'll need to set it up again to use it.
What Happens When Removing?
Device Is Deleted
- ✅ Device disappears from your device list
- ✅ Connection between device and account is removed
- ✅ Device is ready for new setup
Your Data
- ✅ Historical data remains stored in cloud
- ✅ You can still view it in app
- ✅ Export functions remain available
Your historical consumption data is NOT deleted even if you remove the device. It remains linked to your account.
Physically Removing Device
If you also want to remove the device from the electricity meter:
Disconnect Power Supply
- Unplug USB-C cable
- Device is now without power
Remove Device from Meter
- Carefully pull reading head off meter
- Magnetic attachment releases easily
Remove Accessories
- If you used metal disk, remove it
- If Wi-Fi module was separately attached, remove it too
Preparing Device for New Setup
If you're passing the device to someone else or want to set it up elsewhere:
1. Remove Device from App
Follow above instructions
2. Perform Factory Reset (Recommended)
- Perform a Factory Reset
- This deletes Wi-Fi settings and local data
- Device is then like new
3. Hand Over
- Device can now be set up by new person
- New person can connect device with their own account
Adding Device Again Later
You can add the device again at any time:
In the App
- Tap on "+" or "Add Device"
- Follow setup instructions
Device Is Recognized
- If device was previously connected to your account
- Historical data will be automatically linked again
Permanently Deleting Data
If you also want to delete your historical consumption data:
Deleting data is permanent and cannot be undone!
Request Data Deletion
Contact support:
- 📧 info@energieleser.de
- Subject: "Request Data Deletion"
Provide:
- Your email address (account)
- Which data should be deleted
- Confirmation that you want deletion
Data will be deleted within 30 days
Frequently Asked Questions
Can I remove a device and add it again later?
Yes, at any time! Historical data remains preserved and will be linked again when re-added.
What happens to my consumption data?
Data remains stored in cloud and is still visible in your app. It's not automatically deleted.
Can someone else use my device after removal?
Yes, after removal from your account, the device can be set up by another person with their account. We additionally recommend a Factory Reset.
Do I need to perform a factory reset?
It's not mandatory but recommended, especially if you're passing the device on. Factory reset deletes local settings like Wi-Fi credentials.
How do I completely delete my data?
Contact support at info@energieleser.de and request data deletion. This is a manual process for data protection reasons.
Need Help?
If you have questions:
- 📚 See FAQ
- 💬 Community Forum
