LED Signals and Their Meaning
The energieleser.node has four LED indicators that show the current device status. In everyday use, no LED is usually lit — this is intentional and saves battery. This page helps you interpret the signals if an LED does light up.
energieleser.node with the button and the four lit, numbered LEDs 1 to 4
During pairing​
StageLED statusMeaning
Pairing armedLED 1 blinks three times quickly (100ms on / 100ms off)Confirms the 5-second hold was registered
Listening for the BridgeAll 4 LEDs turn on solidStays like this for up to 45 seconds, or until pairing completes
Pairing complete or cancelledAll LEDs turn offThe Node returns to normal operation
See Pairing the Node for the full procedure.
At power-on​
Power on (not yet paired)The LED for Port 1 lights up and stays on for up to about 10 seconds, then all LEDs turn offThe Node then switches to energy-saving mode
Power on (already paired)No LEDsThe Node switches to energy-saving mode immediately — normal after a battery change
Power on via USB-CLEDs 1, 2 and 3 light up for about 60 seconds (a short button press ends it early)Shows that USB-C power is detected
During normal use​
LED statusMeaning
No LEDs litNormal — the Node is in energy-saving mode, where it spends almost all of its time
The LED for one port flashes brieflyA reading was just counted on that port — normal confirmation
During a firmware update​
LED statusMeaning
LEDs chase in order 1 → 2 → 3 → 4, repeating, about every 150ms per stepThe device is in update mode, waiting to receive a firmware file over its USB-C service connection
This pattern is only expected during a firmware update — see Troubleshooting if it appears unexpectedly.
Troubleshooting​
An unrecognised LED pattern is showing​
Compare it against the tables above. If it's the four-LED "chase" pattern and you didn't start a firmware update, simply wait about ten seconds without touching the button — the Node will return to normal energy-saving mode on its own.
The Node does not respond​
If the Node shows no LED even after a short button press:
  • Check the batteries (or USB-C connection) are properly seated
  • Replace the batteries with a fresh pair, or a fresh long-lasting battery + dummy
  • Contact support if the problem continues
Next step​
Learn more about Troubleshooting other common issues with your energieleser.node.
