Software Update (Firmware)
To ensure your device receives the latest features, start the update within the app.
Important
During the entire process, the wärmeleser must not be disconnected from the power supply.
Manual updates
If you want to run an update manually:
- Open the energieleser app
- Go to Device → Maintenance → Firmware update
- Check for available updates
- Start the update if one is available
Update process
- Download update – The update is downloaded
- Install update – The update is installed
- Device restarts – The device restarts automatically
- Confirm update – The new firmware version is shown
After the update
After a successful update you should:
- See the new firmware version in the app
- Check that everything works
- Contact support if there are problems
Next step
Learn more about maintenance of your wärmeleser.
