Multimeter setup
Step 2.2: Create the Combined Script for Two Meters
Combine individual scripts so Tasmota reads data from two meters (built-in read head + TTL1).
Update the Meter Count
to
>M 2
(The number after M shows how many meters are connected — 2 for two meters.)
Add the Second Meter Line
You already have this line for the first meter:
+1,3,s,16,9600,MT175,1
Example meter line for the first meter
Add the line for the second meter on TTL1:
+2,5,s,16,9600,MT175,4
+2 = second meter, 5 = RX GPIO of TTL1 (IO5), 4 = TX GPIO of TTL1 (IO4).
Copy Data Lines and Adjust Meter Number
Copy first meter’s lines, change 1,2, and update names (e.g., E_in → E_in2).
2,77070100010800ff@1000,Verbrauch,kWh,E_in2,3
2,77070100020800ff@1D,Einspeisung,kWh,E_out2,3
2,77070100100700ff@1,akt. Leistung,W,Power2,0
Final Combined Script
->sensor53 r
>M 2
2,=h--
Add a Third Meter on TTL2 (Optional)
The second TTL port lets you read a third meter. Proceed as above:
  1. Set the meter count to >M 3.
  2. Add the meter line for TTL2: +3,-7,s,16,9600,MT175,6 (RX GPIO IO7, TX GPIO IO6).
  3. Copy the data lines, change 2,3, and update the names (e.g., E_in2 → E_in3).
Minus sign in front of the RX GPIO
The minus sign in -7 enables software serial for this meter. The ESP only has a limited number of hardware serial interfaces, and those are already taken by meters 1 and 2. The - makes Tasmota emulate the serial interface in software for the third meter, so it can still be read.
->sensor53 r
>M 3
2,=h--
3,=h--
3,77070100010800ff@1000,Verbrauch,kWh,E_in3,3
3,77070100020800ff@1D,Einspeisung,kWh,E_out3,3
3,77070100100700ff@1,akt. Leistung,W,Power3,0
Maximum of 3 Meters
The stromleser.tasmota 2 has 2 TTL ports. Together with the built-in read head, you can read a maximum of 3 meters.
Next Step
After updating the script, continue with Verification & Troubleshooting.
