Factory Reset
Reset to Factory Settings
To reset the device, press and hold the reset button for 7 seconds.
Tip
The reset button is located on the front of the water reader. Use a paper clip and gently press into the hole to activate the button. After the reset, the LED will start flashing blue rapidly, indicating that the water reader is ready for a new setup.
