LED Signals and Their Meaning
The energieleser.bridge has a status LED. It shows which state the device is in: blue stands for start-up and setup, green for success, red for connecting and errors.
During start-up and setup
| LED status | Meaning |
| Blue blinks quickly | The Bridge is starting up or waiting for setup |
| Green blinks slowly (about 1 second) | The connection to the app is established |
| Double light pulse | WiFi credentials were received, setup is in progress |
| Blue blinks slowly (about 1 second) | The Bridge is waiting for setup |
| Red blinks | The Bridge is connecting to WiFi |
| Green lights solid (about 3 seconds) | Setup completed successfully |
During normal use
| Green blinks five times quickly | The Bridge has connected to WiFi |
| Single short light pulse | Readings were read successfully |
| Red blinks slowly (about 1 second) | No WiFi connection or an error sending the readings |
| LED off | Normal operation |
See Troubleshooting if the LED keeps blinking red.
Next step
Learn more about Troubleshooting common issues with your energieleser.bridge.
